Start BC without intial drawing template
I want starting BC without intial drawing template.
I try add "(command "CLOSE")" into on_doc_load.lsp, but it closing every opened file direct double click.
Is way how run BC without intial drawing template?
Using lisp this works:
Create an on_start.lsp with this content:
(if (zerop (getvar "dwgtitled")) (setvar "users1" "close")) (princ)
Create an on_doc_load.lsp with this content:
(if (= (getvar "users1") "close")
(progn
(setvar "cmdecho" 0)
(command "_.close")
(princ)You could also use a start up switch and a script:
"C:\Program Files\Bricsys\Bricscad V10\bricscad.exe" /b "close.scr"
Content of close.scr:
close0 -
LISP works! Great! Thanks!
Yep, the LISP works great for me as well.
Thank You,
Joe Dunfee0 -
For BricsCAD V14 you do not have to create two Lisp files. Only creating this on_start.lsp is enough:
[code](if (zerop (getvar "dwgtitled"))
(progn
(command "_.close")
)[/code]
For V10 the solution with two files is required to avoid a command line message ('This command is available only when a drawing is open.').0
