ubuntu bricscad v11 custom papersize
How can I define custom paper sizes (example a longer A1).
When I try to edit the custom papersizes in the printing dialog I click in the edit button and nothing happens...
João Bispo
there no way for that even in 11.1.17
Joao, if you really need it, you can create extra paper sizes for your cups-pdf printer by modifying the following file:
/usr/share/ppd/cups-pdf/CUPS-PDF.ppd
This file is plain text ppd and understanding it's contents should be straightforward.
The unit used for dimensions is postscript default unit, point, it equals 1/72 inches, 0.352778 millimeters.
1. Copy the original cups-pdf.ppd to your home directory
cp /usr/share/ppd/cups-pdf/CUPS-PDF.ppd ~/cups-pdf-new.ppd
2. Edit the contents, add the new printer size lines (four lines for a size), you could take a look at the changes I made http://pastebin.com/5PwcXX7X
gedit ~/cups-pdf-new.ppd
3. Load the file for cups printer.
Open System → Administration → Printing
double click on your PDF printer (or open properties)
Under Settings there is "Make and Model: Generic CUPS-PDF Printer", click on the button "Change..." next to it
Choose "Provide PPD file" and point to your newly created file
4. Restart cups
sudo /etc/init.d/cups restart
or
sudo restart cups
5. Close and reopen your program, Bricscad in this case.
Now your new paper size should show up under printing settings.
Mattias, can you explain where cups-pdf save pdf's? I have not find option for custom save the file... and nothing happens when I print to cups-pdf printer.
Andrey, the generated PDF files go to ~/PDF directory (in your home folder). This can be changed globally in /etc/cups/cups-pdf.conf
Mattias, thank you very much. finally I found where my pdf saves
/var/spool/cups-pdf/[$user]
looks like it is default directroy for opensuse 11.3
Yeah, the defaults can vary a lot across distributions and I as a typical ubuntu user falsely assume everyone uses Ubuntu. Glad you got it resolved.
thanks.....
