PlotOutputPath
I want to set my plot output path to the current drawing path
But this line:
(setvar "PlotOutputPath" (getvar "DwgPrefix"))
gives me NIL
gives me the current drawing path fine
but
(getvar "PlotOutputPath")
just gives NIL despite what appears in the Settings dialog box
This is because, while DWGPREFIX is a system variable, PlotOutputPath is a so called 'preference'. You can get (and if applicable set) a system variable's value simply by typing it's name on the command line or via (getvar xxx) /(setvar yyy newvalue).
: dwgprefix
DWGPREFIX = "C:\Users\ferdinandj.BRICSYS\Favorites\Documents\" (read only)
To Get (/or Set) a preference is a bit more complicated.
Preferences live in the registry (user profile)
the typical location of the 'PlotOutputPath' preference is:
HKEY_CURRENT_USER\Software\Bricsys\Bricscad\V10\en_US\Profiles\PROFILENAME\Config\Plot
Following Lisp function returns the value of the PlotOutputPath preference:
(defun getPlotOutputPath (/ thisProf thisKey)
(setq thisProf (vla-get-ActiveProfile (vla-get-profiles (vla-get-preferences (vlax-get-Acad-Object)))))
(setq thisKey (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" thisProf "\\Config\\Plot"))
(vl-registry-read thisKey "PlotOutputPath")
)0 -
Cool! Thanks.
So how do I set "PlotOutputPath"?
I know, I should start digging into Visual Lisp.
I'm sure I can figure it out on my own.
Can anybody recommend a good online resource for all that Vl-, Vla- etc. stuff?
I'm fairly good with conventional (Autocad R14) Lisp
0 -
Try: http://www.asmitools.com/Files/AutoLISP_Help/AutoLISP%20Help.html and look for: vl-registry-write
0 -
Thanks!
0
