Pfad für Plotterkonfigurationsdatei
Hallo,
kann man den Suchpfad für die Plotterkonfigurationsdatei immer auf das Projektverzeichnis setzen.
In acad gibt es hierfür das lsp-Programm linkplotstyle.
Besten Dank im Voraus.
0
Hallo,
I'm not familiar with lisp. But here is al link to a PlotCfgPath solution with VBA (in German only, sorry):
Hope this helps.
Best regards
Peter0 -
many thanks for the fast help. perfect
Best regards Jürgen0 -
Hi Peter,
thanks for the link, interesting post and a nice idea.
Here is the same using LISP
[code]; SetPlotCfgPath
; Sets the Plot Config Path relative to the current drawing
(defun SetPlotCfgPath ( / dwgpath)
; find current drawing path
(setq dwgpath (getvar "DWGPREFIX"))
; Set Plot config path to the drawing path
(setvar "PlotCfgPath" dwgpath)
(prin1) ; make a quiet exit
)[/code]
BricsCAD makes it easy as most settings are accessible via setvar. This function wouldn't work in AutoCAD.
You could take this a little further to include the path to Plot Styles, and give the option of using a folder relative to the current drawing
[code]; SetDwgPlotPaths
; Sets the Plot Config & Plot Style Path relative to the current drawing
; Can also set a folder to use
(defun SetDwgPlotPaths ( / dwgpath plotcfgfolder plotstylefolder plotcfgpath plotstylepath)
(setq
dwgpath (getvar "DWGPREFIX") ; find current drawing path
; set Plot Config folder.
; leave blank "" if you want to use the current drawing folder
; enter foldername "plotconfig" to use a subfolder relative to the current drawing folder
; prefix "..\\" to the folder name if you want to use a folder relative to the parent folder
plotcfgfolder "plotconfig"
; set Plot Style folder.
; enter foldername "plotstyle" to use a subfolder relative to the current drawing folder
plotstylefolder "plotstyle"
plotcfgpath (strcat dwgpath plotcfgfolder) ;set plot config path
plotstylepath (strcat dwgpath plotstylefolder) ;set plot style path
) ; end setq
; Set Plot Config path relative to the drawing path
(if (findfile plotcfgpath) ; if the plot config path exists
(setvar "PlotCfgPath" plotcfgpath) ; THEN set PlotCfgPath
(princ (strcat "\nPlot Config Folder: " (chr 34) plotcfgpath (chr 34) " not found")) ; ELSE prompt user
) ; end if
; Set Plot Style path relative to the drawing path
(if (findfile plotstylepath) ; if the plot style path exists
(setvar "PlotStylePath" plotstylepath) ; THEN set PlotStylePath
(princ (strcat "\nPlot Style Folder: " (chr 34) plotstylepath (chr 34)" not found")); ELSE prompt user
) ; end if
) ; end DEFUN SetDwgPlotPaths[/code]
You would include the function you want to use in your on_doc_load.lsp and then call it using startup function
[code]; STARTUP
; Automatically runs on load
(defun S::STARTUP ()
(SetPlotCfgPath) ; set plot config path
(SetDwgPlotPaths) ; set plot config & style path
(setq S::STARTUP ())
(prin1)
); end DEFUN S::STARTUP[/code]
Regards,Jason Bourhill
0 -
Hi Jason,
thank you for your great hint! Sorry, I'm in a hurry, but I will try it out on the weekend.
Best regards,
Peter
IBB Ingenieurbüro Battefeld0 -
Hi Jason,
a little late, but here is my feed back: FINE, Thanks!
Best regards,
Peter
IBB Ingenieurbüro Battefeld Bricscad Blog0
