Printing views
Hello!
I just switched from BricsCAD V11 to V13.2.8 and having problems with printing views.
Though the drawing has a lot of views it is not possible to choose one of theese views in print settings.
When I will chose plot area only current view is avalible.
How can I fix this?
/Arne
0
So when you invoke VIEW command all your views are listed, but when in Print Dialog, selecting VIEW, there are none of your views listed in the dropdown list (under default "Current View")?0
Yes, current view is the only choice. None of the ones I have named is avaliable in the drop down list.0
Please file a support request and add your drawing in attachment.0
