Paper Space plot differences ver 12.1.4 - ver 14.1.11
I just started printing to PDF (Bluebeam) from ver 14.1.11
I see there is a difference between the results of same job from 12.1.4 to 14.1.11
12 plots whole of sheet, 14 truncates.
I normally select the exact edges of my sheet and traditionally that has worked every time. They are standard A3 sheet sizes.
But only way to get all to plot is to select print window marginally outside the sheet extremities.
I had this happen in past with IntelliCad and was told that's how it's designed to work, but then I came to Bricscad and found otherwise.
Are there additional settings I am unaware of outside the Print settings that come up when Ctrl P is used, that I have missed?
I use Plot Scale 1, Centre on page, Portrait, millimetres, Plot area - Window. I can't see any other area for changes. (other than increase the 'Windowed plot area'.)
I know that is the obvious(increase plot area), but as it didn't work like that before and it takes more care to chose beyond the page I'd prefer old ways.
help appreciated thanks.
Richard
Richard
0
According to the Release Notes a plot scale problem was solved in V14.1.11 (SR42722). Are you sure you are using V14.1.11?0
This is what shows for my version.
Version 14.1.11 revision 32511
Not sure what the (SR42722) refers to in your post Roy.
Maybe mine is a slightly earlier version of 14.1.11 ?0 -
SR42722 is a support request number. See the Release Notes. FWIW: I have tested 'exact edge' selection in 14.2.06 and experience no problems using PDF reDirect.0
That link leads to a page that says "Release notes not found." Are they no longer available?0
Sorry, answered my own question. It is still available.
The link should be simply http://www.bricsys.com/common/releasenotes.jsp, without the ?i number, so that it opens the latest version.0 -
Please notice Release Notes can be opened from the What's New page in the BricsCAD Help.0
