Live Viewport
I am wondering what would be the best way to create drawings from a 3d model. I am new to 3d and the current way I have been creating drawings can be a pain because when I add a component to the model I have to redo all of my sections and re-annotate everything.
This is the way I have been creating my drawings:
- In model space I execute viewbase command
- It brings me into paperspace I set the views
- One I have my elevations from model I then use the viewsection command in paperspace to get all required sections.
- annotate sections and elevations
- send the drawing to client
- client adds things
- redo steps 1-5 because I do not know how to update existing sections in paper space to show added part.
Is there a way that I can go about either updating the existing sections, or are there other ways to go about detailing drawings. My clients are always changing things, and would like to find a faster way.
Thanks!
Use BricsCAD BIM. BIM sections, plans, elevations, details, ... match changes in the 3D model when updated.
0 -
At the first prompt of the _ViewBase command press Enter to confirm you want to use the 'Entire model'.
0 -
Thanks Roy, that seems to work!
0
