Page setup
Can anybody explain, how can I assign a Page setup to a Layout?
Via Drawing Explorer, I can import a Page Setup from another drawings.
but from this point I cannot assign this Page Setup to a Layout.
The only way I can use this Page Setup is when publishing.
I want to see this Page Setup assigned to my Layout before publishing it,
I want to see if the setup is correct. To make changes "real time" not after it is published.
I need the PageSetup, to manipulate one Layout and publishing 100, if I don't use a page Setup and I have to change something (like the assigned plot style table, or the position of the plot area etc...), I have to go through 100 Layouts manually...
Do I miss something? Is there a solution?
In the Page Setups panel of the Drawing Explorer you can select the page setup for a layout by changing its 'Based on' field. You can also do this for multiple layouts at once.
0 -
Thank You, Roy!
0
