What command - to stitch 3D faces together? ANSWERED.
Hi GrahamG,
Try DMSTITCH
Kin
0 -
AFAIK
If you have 3D Faces, you have to convert them to Regions first.
(Select - Create Region)Then you can stitch them and will get a Solid
(if it was a proper Volume)
or a Surface.Which you should be able to convert/degrade to a Mesh, if needed.
0 -
Thanks Michael,
Convert to Regions - then DMSTITCH did the ‘trick’…
Saved as a surface.Best….
0
