.dwl files
Hi,
Is there a way to not show .dwl files in the finder? - Platform: macOS (Big Sur 11.5.2)
(see example attached - these 2x .dwl files appear on every .dwg.)
ie: Is there an option to turn off in settings, so the files don't appear.
Best... Graham
I am sure there are ways to prevent displaying certain File Types
by some advanced Terminal Commands,
but that is far above my pay grade and may be a bit risky and
just a Workaround.It is a bit annoying and does not help to read your File Structure
or Project Hierarchy.
And it is not only *.DWL but also *.BAK, Import Logs and the like,
which clutter your alphabetic order in Finder.Not sure if that is something Bricsys could easily improve.
I personally would vote for packing all these secondary File Types
into a single Folder, beside the Drawing Files.Or basically I would prefer to have all the *.BAK Files in my custom
local Auto Backup Directory Path (which may be a problem when
accessing the Drawing Files from other Machines)I think it is worth to file a Support Request and get Bricsys View
and opinion.0 -
On Windows, you can hide the DWL files by selecting "Don't show hidden files, folders, or drives" in the View tab of the Folder Options palette (Windows Explorer > View > Options > Change folder and search options).
When I was using a Mac, about 25 years ago, I don't think it had an option to show hidden files. It had far more hidden files than Windows had, but wouldn't let me see them. Whenever I'd send a file to a Windows computer, another file would be sent along with it, one that I couldn't see on the Mac.
0 -
There are several Apps that will switch that for you (e.g. Pathfinder)
or there are Terminal Commands.Usually everything on Mac is hidden by default when it starts with a dot.
Like Bricscad's hidden Config File called .configBut the easiest way to switch (similar to Linux) hidden Files Visibility on Mac is By
SHIFT+CMD+.0
