How to get the surface area of a tinsurface?
in 3D Modeling
Hi,
I need to find out the area in m² of tin surface. In order to check this, I made an example tin-surface from the shown profile:
This tin should have a surface-area of 14m² or 1400cm². Since I can't find this number in the statitstics, I presume it is not shown.
Is there a way to find out the surface of a tin?
Thank you!
Thank you!
0
Try massprop command.0
upload a DWG with your TIN to check...0
