Textsize civilpoints
in 3D Modeling
How do I change size on the text to civilpoints? When I print drawings the text is to small to read.
0
Click on the "Civil Explorer" in the left side of the ribbon, click on Civil Points > Label Styles > Default, right click and edit as desired.0
I use Bricscad v22, is it the same way to do?Terry Dotson said:Click on the "Civil Explorer" in the left side of the ribbon, click on Civil Points > Label Styles > Default, right click and edit as desired.
0 -
I draw elevations using civil points. When I print drawings, the text becomes far too small to be able to read. How do I change this?0
