Layers don´t work [SOLVED]
hello everyone
I want to resize my hidden lines in VP Lineweight.
When I go in Driwing Explorer and try to change from Default to 0.9 mm. and then print.
The results are always the same. All lines are the same,
the program does not resize lines.
Don't know if I am doing right or wrong, any help would be greatly appreciated.
0
see attached screenshot - is "Plot entity linewhigt" checked?
0 -
Yes.
0 -
what about LWDISPLAY var?
0 -
Hello,
Hello,
now it works properly.
Done in this order:- change BM_Hidden (see picture)
- change in VP BM_Hidden (see picture)
0
