Editting an imported DWG file
in 3D Modeling
please help how to make the imported dwg part/item connect to other library items using BMConnect.?
0
Hello.
BMCONNECT only works with some special mechanichal blocks, not with any entity or drawing.
You can experiment with this feature using the components in the library in Standard Parts > Piping.
There are some special layers required for the feature to work.
These layers contain geometry that is used to automatically create constraints.
Also, there are some mechanical settings required - they are displayed in Mechanical Browser.The structure of a drawing that is used with BMCONNECT needs to be exactly as it is with these components.
More information about the topic can be found in the next articles.
0
