Is there any method to fill a shell? (mesh or surface)
I trying to migrate some files created from sketchup imported to dwg, but with sketchup always I have problems.
Is there any method to fill (like to fill a glass with water) to convert mesh or surface or any 2D objects to solids?
1
There are various methods, depending on the source geometry, and in some cases you may need to take intermediary steps to achieve. DMSTITCH would be one option to investigate.
1 -
"Sketchup is a special case with its double Faces for 2-sided texturing"
That explains a lot! Thanks.
1
