dynamic text in attribute
Hello,I want to add an attribute with dynamic text to a block.Our attribute should have a default value followed with a asked value.for example:A block with attribute “boring”. The displayed value should be “boring” followed with a requested value asked in command line. Every time we insert a block it should ask only the number.Second, it should be a movable attribute (the whole text).
image">
  • To my knowledge this is currently not supported in Bricscad. You could try creating a lisp function to accomplish this.
  • hi,
    I never worked with lisp.
    can you recommend me a good website to accomplish this with lisp as a beginner?
    thanks in advance
  • Hi Alexander,
    Have you seen our GeoTools product? We have a tool to interactively move and rotate attributes from existing blocks.
    See below:
    http://www.4d-technologies.com/geotools/manual/block_tools.htm#ATTMOVE
    From your sample image shown, it appears this is exactly what our GT_ATTMOVE command does.
    Are you asking for a tool that would allow you to interactively place a block and then ask for a location for the attribute. That would be a good enhancement or opportunity to create a new tool.
    GeoTools is entirely in Lisp.
    Regards
    Rakesh Rao
    Blog: http://rakeshrao.typepad.com
  • @ Alexander:
    If you want to learn more about lisp I highly recommend this German website:
    http://www.autolisp-tutorial.mapcar.net/
    Another interesting site:
    http://www.afralisp.net/
    A few lessons from afralisp have been translated into Dutch:
    http://www.cadsite.be/lisp/lisp.php
    Below is some code that may work for you. Using the examples c:Bor and c:Test you can create your own functions.
    (defun InsertNumBlock (block scale ang pre suf / i oldAttdia pt quotedGlobalVar)
    (setvar 'cmdecho 0)
    (setq oldAttdia (getvar 'attdia))
    (setq quotedGlobalVar (read (strcat "*globalNr" block "*")))
    (if (not (eval quotedGlobalVar))
    (set quotedGlobalVar 1)
    (if (setq i (getint (strcat "\nStart number <" (itoa (eval quotedGlobalVar)) ">: ")))
    (set quotedGlobalVar i)
    (while (setq pt (getpoint "\nInsertion point or ENTER to quit: "))
    (setvar 'attdia 0) ; since there is no error function change attdia as late as possible...
    (command "_.insert" block pt scale scale ang (strcat pre (itoa (eval quotedGlobalVar)) suf))
    (while (> (getvar 'cmdactive) 0)
    (command "")
    (setvar 'attdia oldAttdia) ; ... and change it back to the old value as soon as possible
    (set quotedGlobalVar (1+ (eval quotedGlobalVar)))
    (princ)
    (defun c:Test ()
    (InsertNumBlock "TestBlock" 1 0 "Text before number " " text after number")
    (defun c:Bor ()
    (InsertNumBlock "boring" 1 0 "Boring " "")
  • @Roy Klein Gebbinck
    thanks for this great reply,
    Time to learn some lisp :-D
