Pfad für Plotterkonfigurationsdatei
Hallo,
kann man den Suchpfad für die Plotterkonfigurationsdatei immer auf das Projektverzeichnis setzen.
In acad gibt es hierfür das lsp-Programm linkplotstyle.
Besten Dank im Voraus.
  • Hallo,
    I'm not familiar with lisp. But here is al link to a PlotCfgPath solution with VBA (in German only, sorry):
    Hope this helps.
    Best regards
    Peter
  • many thanks for the fast help. perfect
    Best regards Jürgen
  • Hi Peter,
    thanks for the link, interesting post and a nice idea.
    Here is the same using LISP
    [code]; SetPlotCfgPath
    ; Sets the Plot Config Path relative to the current drawing
    (defun SetPlotCfgPath ( / dwgpath)
        ; find current drawing path
        (setq dwgpath (getvar "DWGPREFIX"))
        ; Set Plot config path to the drawing path
        (setvar "PlotCfgPath" dwgpath)
        (prin1) ; make a quiet exit
    )[/code]
    BricsCAD makes it easy as most settings are accessible via setvar. This function wouldn't work in AutoCAD.
    You could take this a little further to include the path to Plot Styles, and give the option of using a folder relative to the current drawing
    [code]; SetDwgPlotPaths
    ; Sets the Plot Config &  Plot Style Path relative to the current drawing
    ; Can also set a folder to use
    (defun SetDwgPlotPaths ( / dwgpath plotcfgfolder plotstylefolder plotcfgpath plotstylepath)
        (setq
            dwgpath (getvar "DWGPREFIX") ; find current drawing path
            ; set Plot Config folder.
            ; leave blank  "" if you want to use the current drawing folder
            ; enter foldername "plotconfig" to use a subfolder relative to the current drawing folder
            ; prefix "..\\" to the folder name if you want to use a folder relative to the parent folder
            plotcfgfolder "plotconfig"
            ; set Plot Style folder.
            ; enter foldername "plotstyle" to use a subfolder relative to the current drawing folder
            plotstylefolder "plotstyle"
            plotcfgpath (strcat dwgpath plotcfgfolder) ;set plot config path
            plotstylepath (strcat dwgpath plotstylefolder) ;set plot style path
        ) ; end setq
        ; Set Plot Config path relative to the drawing path
        (if (findfile plotcfgpath) ; if the plot config path exists
            (setvar "PlotCfgPath" plotcfgpath) ; THEN set PlotCfgPath
            (princ (strcat "\nPlot Config Folder: " (chr 34) plotcfgpath (chr 34) " not found")) ; ELSE prompt user
        ) ; end if
        ; Set Plot Style path relative to the drawing path
        (if (findfile plotstylepath)  ; if the plot style path exists
            (setvar "PlotStylePath" plotstylepath) ; THEN set PlotStylePath
            (princ (strcat "\nPlot Style Folder: " (chr 34) plotstylepath  (chr 34)" not found")); ELSE prompt user
        ) ; end if
    ) ; end DEFUN SetDwgPlotPaths[/code]
    You would include the function you want to use in your on_doc_load.lsp and then call it using startup function
    [code]; STARTUP
    ; Automatically runs on load
    (defun S::STARTUP ()
        (SetPlotCfgPath) ; set plot config path
        (SetDwgPlotPaths) ; set plot config & style path
        (setq S::STARTUP ())
    (prin1)
    ); end DEFUN S::STARTUP[/code]
    CAD Concepts
    SetPlotConfig.lsp
  • Hi Jason,
    thank you for your great hint! Sorry, I'm in a hurry, but I will try it out on the weekend.
    Best regards,
    Peter
    IBB Ingenieurbüro Battefeld
  • Hi Jason,
    a little late, but here is my feed back: FINE, Thanks!
    Best regards,
    Peter
    IBB Ingenieurbüro Battefeld Bricscad Blog
