Autocads Data Link Update in BricsCad
 I don't have any experience with Cad programs, but an user got to me, saying he needs Autocad because he can't update data links in BricsCad. I would like to check if there is really no option for this in BricsCad before spending the bucks on AutoCad.
The issue is that they created an template with a table in it with linked data. If they draw some lines of a particular type they can run the following command in AutoCad to update to total length : Data Link Update .
Is something similar possible in BricsCad?
  • Some months ago I have created a Lips utility called "Field_Lisp_Variables" (original thread).
    I have now created an updated version that can also 'emulate' this type of 'Data Link'
    > Field Lisp Variables (FLV) Utility for BricsCAD (20160826)
    > With this utility you can display text portions, the content of text files and
    > certain selection set data (area, count, perimeter) in fields. Fields can be
    > used in Mtext objects and Table objects.
    > The utility is Lisp-based and requires only a limited amount of work to set up.
    Field_Lisp_Variables_20160826.zip
Howdy, Stranger!
It looks like you're new here. Click one of the buttons on the top bar to get involved!
