Howdy, Stranger!
Edit attribue value in block with rollover + ctrl
Hi
When editing text it's useful and fast to edit the value when hovering over the text and edit the content directly.
How can I do the same with attributes in blocks ?
I have discovered if I hover the attribute and press ctrl I get a rollover box (Nested Attribute, just like when I change texts) where I'm able to change the attribute value, rotation etc depending on what I've set in rollover properties for attributes.
There is only one big problem. I make the changes in the rollover box for nested attributes but nothing changes in the block.
Any suggestions ?
In Autocad you get the block reference box, when selecting the block, beside the block where you can edit the attribute values directly (if you have location mode = cursor) .
Sign In or Register to comment.
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
