Aerial Image assingned to a box.
How does one attach a aerial image to a 3D solid box 1:1?
I want to use this to export to fbx. The image is exact the same size as the solid.
In the mean time i just keep trying some
Thanks!
  • edited December 2020
    Basically you can create a Material,
    apply the image as diffuse/color Texture
    and apply a "Texture Size".
    I think these are INSUNITS
    (Although your image is not quadratic, I think you need to apply
    the larger Edge's value)
    Yes, I tried, it works.
    You even don't need to add an Offset from origin,
    as Bricscad starts the Texture from an Object Edge.
    Here is my modified File :
    BTW,
    You have to reapply the Texture File/Path to Diffuse Map
  • Thanks ! Worked out
