Section Planes & POintclouds
Alij
edited April 2021 in Point Clouds
I have Pro version. Do section planes work with Pointclouds as I have tried but it cuts everything but the pointcloud. It is probably user error as I also do not seem to be able to crop the point cloud in V21 as I have done in V20.
Thanks
  • AFAIK latest V21.2 will allow to create any Solid Geometry
    to be assigned as a Clip Volume for Point Clouds.
    (If I read release notes correctly)
  • section planes are supposed to work on pointclouds too. And as Michael mentioned, there's a new functionality in V21.2 called POINTCLOUDCROPSOLIDS, which enables you to convert an extruded solid (a BOX or CYLINDER for example) to a 3D cropping entity for pointclouds.
    If you can't even crop the pointclouds with POINTCLOUDCROP I would suggest you fill in a support request so that the issue can be examined further.
Sign In or Register to comment.
Howdy, Stranger!
It looks like you're new here. Click one of the buttons on the top bar to get involved!
