Expresstools- TextMask ... error too few / too many argument (solved)
edited April 7 in 2D Drafting
since Bricscad v24, the textmask command in the expresstools menu gives me the following error.
----- Error around expression -----
(BCET$GET_MESSAGE "textmask_msg_main")
in file :
C:\Program Files\Bricsys\BricsCAD V25 en_US\ExpressTools\textmask.des
* too few / too many arguments at [ACET-STR-FORMAT]
All other expresstools functions seem to work.
Do you have a solution?
  • edited April 3
    Works in V25, the clue may be the ACET command not loaded.
    Copy this to command line (acet-util-ver) if you get say nil then not loaded, look at this link
    https://www.google.com/search?q=how+to+load+ACET+functions+bricscad&sca_esv=a413dd12ff7c5a78&sxsrf=AHTn8zpu9UTPKkw_5vcZWxQSkUImwzBEjg%3A1743718699994&ei=KwnvZ528PPuVjuMP3sKY-A8&ved=0ahUKEwjd_c2t8ryMAxX7imMGHV4hBv8Q4dUDCBA&uact=5&oq=how+to+load+ACET+functions+bricscad&gs_lp=Egxnd3Mtd2l6LXNlcnAiI2hvdyB0byBsb2FkIEFDRVQgZnVuY3Rpb25zIGJyaWNzY2FkMgcQIRigARgKSJk4UNQIWIktcAF4AJABAJgBhwKgAcgVqgEGMC4xMi4zuAEDyAEA-AEBmAIQoALGFsICDhAAGIAEGLADGIYDGIoFwgILEAAYgAQYsAMYogTCAgsQABiwAxiiBBiJBcICBBAjGCfCAggQABiABBiiBMICCBAAGKIEGIkFwgIFEAAY7wXCAgUQIRifBZgDAIgGAZAGCJIHBjEuMTIuM6AH5UiyBwYwLjEyLjO4B78W&sclient=gws-wiz-serp
  • Hello Alanh
    thank you for your reply.
    I used the command and I get “1.38”.
    I think it's the version number.
  • Sorry can not help anymore ran out of ideas.
  • problem solved.
    In my settings, the "support file search path" pointed to an old directory. I changed it to the “express tool” directory of the new installation and I no longer have the problem.
