Door insertion ignoring nearest wall (solved: wall mitering)
mallenb
edited 6:00PM in BricsCAD BIM
Inserting a door seems to only show my distance to the end of the actual wall its being inserted into. Is there a way to get it to recognize the distance to the perpendicular wall?
Being new to BIM, I'm now wondering if this is the incorrect way to draw this wall situation.
  • Hello,
    If your walls are connected, the distance to the perpendicular wall should be recognized.
    If the walls are connect, please create a Support Request and attach the drawing where you can reproduce this issue.
  • Before I submit a ticket - is "connected" different than "touching"? Is there something special I have to do to make walls connect? (Like the example above, I'm talking about when two walls come together at a "T".
    I just now created a new empty drawing and used Quick Draw to make a simple 4 wall room with slab floor. I used "wall" with the "single wall" option in the dialog box to place a wall within the 4 main walls. This wall was automatically placed touching two of the outer 4 walls.
    I then try to insert a door or window (or anything) on a main wall, and the interior wall is not recognized when I place the object on the main wall.
  • mallenb
    edited 5:57PM
    Support responded (thanks!) Bricscad is operating as designed. To get objects to recognize perpendicular walls, the walls in question need to each be separate entities. T shaped connections need to look like the photo below, as opposed to my original example above.
    I wish walls automatically did this (I'm attempting to migrate from Autocad Architecture where windows and doors automatically recognize perpendicular walls without any special preparations)
