Autosave timer
Im experiencing a small problem with the autosave timer.As the extaordinary causious user I am I of course hit my save button all the time. If Im really good at it I may work for hours without getting an .sv$ file. Wich has just happened to me. For some reason it finally crashed and the file is busted. My opinion is that it should kick in EVERY .. minutes wether you save or not.
  • There are two backup mechanisms:- SV$ autosave mechanism- bak backup mechanism that stores the previous revision of your drawing.I would think that in your case there would be a recent and intact bak file. Still, we will consider the change that you suggest. regards,Alexander Van HeuverzwynBricscad
  • Patrick,Did you crash during a "print preview"? If so, this is a problem that has been with Intellicad since Icad 98. I always do a quick save before print preview.
