Tablet calibration
In Windows XP the Tablet OP-1812N with WinTab 1.1 is indicated and it also reacts. If I begin AutoCAD MAP 2009, give in the command Tablet + cal: for digitizing of the first points also displayed which reacts the tray - the coordinates change with move.In Briscad newest version this is not in such a way. To digitalize of the first point is not evident whether the tray is demanded - the coordinates don’t change with move.So I think the problem is not the tablet, it works in Autocad. The way to dititize is the same in the two programs, but Bricscad reacts different.
Oliver, I also have had problems generating coordinates from a calibrated tablet. I have used the current beta version and found I can calibrate my tablet and digitize accurate coordinates. I use the Wintab driver from Calcomp TabletWorks software.I'm not sure when a release will be made with this support, perhaps someone else will comment on that.
0 -
The tablet related code has been entirely reworked in Bricscad V9.3.Release of V9.3 is scheduled for June.Kind regards.
0
