GROUP & ungroup
I have LISP that creates a simple table and adds all of the table entitities (line & text) to a group. The problem is ungrouping it if I want. My boss goes right for the explode command, but that does not work. The only way I know of is to ungroup it through the group dialog.
Are there plans to make the explode command ungroup groups?
Has anyone created a new explode command that will check for groups?
Thank You
Steve
Dear Stephen Marcotte,
This should be helpfull:
http://web2.iadfw.net/terrycad/LISP/Groups.lsp
Regards, Roy.
0 -
thanks for the code...
0 -
Hi Mr. Marcotte : )
I use the heck out of groups and have been meaning to put something together for a while now to prevent the exploding of groups, I think some sort of reactor might do the trick. Also Maybe setting a key to toggle the pickset variable and a little education might help. I will try to code something up in the next couple of weeks.
Dan
0 -
Thanks for the comment regarding the pickset setting (PICKSTYLE variable)... i really never looked into this topic. In my particular situation going with a block instead of a group is the best bet for me... All i'm really trying to accomplish is "making it difficult to screw up a table when you move it". If the user wants to edit it then they can just explode it.
Thanks
steve
0
