bks object
How can I adjust the BKS on the end of an arc? The command "bks e" always takes the startangle, independent from the pickpoint.
Sorry, BKS (german) is the same like UCS.
0 -
Dear Martin Breternitz,
This problem doesn't occur in BC7 (which I still use). But you could try this:
:ucs
?/3point/Delete/Entity/Origin/Previous/Restore/Save/View/X/Y/Z/ZAxis/<World>: z
Enter angle of rotation about Z axis <0>: cen
Snap to centerpoint of:
Second point: end
Snap to endpoint of:Regards, Roy.
0 -
...thanks. I use the latest version and I know this option, but the direct way would be much easier to use...
0 -
The problem has been solved in version 9.3.10, which is currently not available yet in German though. Since the translation is almost finished, the German version is to be expected soon.
0
