Gouraud ShadeMode not working
Hi the Gouraoud option in Shademode command is not working fine i mean to say it does not display the model in smoothed mode it displays in Flat or non-smoothed mode. Can anybody help me
Thanks Sanjay.
We are working on a fix, which will be included in an upcoming v9.3 update.
0 -
When you are at it will you also fix the inverted perspective you always get.
The model expands away from you. I am amazed no one else has complained.
This has been the same since V8
0 -
The apparent distortion of perspective is most likely due to the isometric projection used in technical drawings. In this projection, parallel lines stay parallel out to infinity rather than converging to one or more vanishing points.
This projection has quite a few advantages in mechanical drawings but it will fool the eye, which sees lines that fail to converge in the distance as actually diverging "in reality."
See http://en.wikipedia.org/wiki/Isometric_projection for a discussion.
0 -
What abouth Hidden mode, or the HIDE command?
I get an extra diagonal on all faces.
0 -
Ragnar, you're right: something seems to have gone wrong while implementing support for the DISPSILH setting. When switching DISPSILH On, you will get rid of the diagonals, while in fact this should not depend on DISPSILH. We'll investigate the issue.
0 -
Thanks. I entered this as a support case also.
0 -
HA! Now I saw the readme file:
HTML clipboardSR20329 - DISPSILH: Enabled displaying of silhouettes in HIDE and SHADE commands.
0
