Saving more files
Bonjour,
Request for feature:
Possibility to save all open files in one click, when needed.
Therefore add 'Save All' Button in the File menu (this is current feature in softs)
Use case (justification) : when reopening 10 files for a small identical manipulation, this would be quicker and less deconcentrating from main task.
Yours,
PY Delens
0
You can use _closeall at the command line. It will close all open drawings and prompt you to save if needed. Using Customization (CUI) you can add closeall to the File menu.
0 -
Merci
0
