Ugrade Limit?
I tried to upgrade my bricscad v9 to v10. It says "invalid key". I notice that there is a note saying there is only on upgrade allowed. Does bricscad stop you from upgrading more than once?
Mine does too. I sent a support request, I expect it's just a hiccup.
There is a knowledge article on that possibly happening in Vista, but I use XP.
Unless the trial and registered versions are different downloads, but it does not seem so.
0 -
Under Registration > My Stuff, you can see all your past license keys.
My V10 key not there (although payment shows up), which makes sense I guess - it probably takes a little time to generate.
Funny thing is the key I saw while buying V10 is the old one for V8. My V9 is obviously more recent.
0 -
Upgrading should work again, there was a small oversight in the settings.
If you experience more problems, please let us know.0
