LISP: entmod doesn't work on viewports in BC10 10.1.4 (Trial)
This code works fine in BC7. Does anybody know why it fails in BC10 10.1.4 (Trial)?
(defun c:ShiftVP ( / )
(if
(and
(setq entName (car (entsel "Selelect viewport: ")))
(setq entLst (entget entName))
(setq entType (cdr (assoc 0 entLst)))
(or
(= entType "VIEWPORT")
(and
(= entType "LWPOLYLINE")
(setq entName (cdr (cadr (member '(102 . "{ACAD_REACTORS") entLst))))
(progn
(terpri)
(princ entLst)
(setq entLst (subst (list 12 0.0 0.0 0.0) (assoc 12 entLst) entLst))
(terpri)
(princ entLst)
(entmod entLst) ; entmod works in BC7 but not in BC10, using entmake will work in BC10 on unclipped viewports
(princ "\nThis is not a viewport ")
(princ)
0
here's a hack you might try
(defun c:ShiftVP ( / app doc entlst entname enttype vpobj)
(setq APP (vlax-get-acad-object)
DOC (vla-get-activedocument APP)
(if (and
(or
(and
entLst
(progn
(setq vpObj (vlax-EName->vla-Object entname))
(vla-put-mspace doc :vlax-true)
(vla-put-activepviewport doc vpObj)
(vla-zoomcenter app (vlax-3d-point 0 0 0) 1)
(vla-put-mspace doc :vlax-false)
(princ)
)0 -
Thank you Daniel. Your "hack" works. You did however move one parenthesis to a wrong place.
If you want to test this:
- Create a pologonal viewport.
 - Use draworder with the option back on the viewport.
 - If the user now selects the viewport he is in fact selecting the lwpolyline.
But thanks again.
Your code with parenthesis in the right place:
(defun c:ShiftVP ( / app doc entName entLst entType vpObj)
(setq
app (vlax-get-acad-object)
doc (vla-get-activedocument app)
(if
(and
(or
(and
(progn
(princ)
)0 -
Daniel: your "hack" somehow also changes the vp scale.
0 -
Sorry my bad, see if this one maintains the scale
(defun c:ShiftVP ( / app doc entlst entname enttype vpcscale vpobj)
(setq app (vlax-get-acad-object)
(if (and
(setq entName (car (entsel "Select viewport: ")))
(or
(and
entLst
(progn
(setq vpcscale (vla-get-customscale vpObj))
(vla-put-customscale vpObj vpcscale)
(princ)
)0 -
Great Daniel. The final result:
(defun c:ShiftVP ( / entName entLst entType pt1 pt2 dist ang vpScale vpOldCenter vpNewCenter app doc vpObj vpOldScale)
(if
(and
(setq entName (car (entsel "\nSelelect viewport: ")))
(or
(and
(setq pt1 (getpoint "\nEnter base point: "))
(= (type pt1) 'list)
(setq pt2 (getpoint pt1 "\nEnter second point: " ))
(= (type pt2) 'list)
(progn
(setvar "cmdecho" 0)
(command "_.undo" "_begin")
(setq
pt1 (trans pt1 1 0)
pt2 (trans pt2 1 0)
dist (distance pt1 pt2)
;; if the vp center moves to the right the vp content shifts to the left so (angle pt2 pt1) is used here:
ang (angle pt2 pt1)
vpScale (/ (cdr (assoc 41 entLst)) (cdr (assoc 45 entLst)))
vpOldCenter (cdr (assoc 12 entLst))
vpNewCenter (polar vpOldCenter ang (/ dist vpScale))
vpObj (vlax-ename->vla-object entname)
vpOldScale (vla-get-customscale vpObj)
(vla-zoomcenter app (vlax-3d-point (trans vpNewCenter 2 0)) 1)
(vla-put-customscale vpObj vpOldScale)
(command "_.undo" "_end")
(princ "\nError: not a viewport or an invalid point ")
(princ)
)0
