Print preview delay
Whenever I try to generate a print preview from the print menu, it takes several minutes for the preview to appear.  During this time I cannot perform any other tasks.  Why does this happen?
  • It would help a lot to know which Bricscad version you are using, to know something about the (network?) printer(s) you use, to know if the size of the drawing influences this delay time.
    May we kindly ask to file a support request and include detail concerning the abovementioned, we will be glad to investigate what is causing the delay.
Welcome!
It looks like you're new here. Sign in or register to get started.
