Installing ACAD.pat files
I've placed a customized acad.pat in my C:\Users\paul\AppData\Roaming\Bricsys\Bricscad\V10\en_US\support.
How does one access these hatch patterns? They don't show up in my Hatch Pattern Palette.
0
Paul, I believe you still need to append your custom hatch patterns to the default.pat (imperial) or iso.pat (metric) files. Bricscad determines which file to look in based on the value of the MEASUREMENT variable. The variable can be set from the config settings dialog. The UNITS command will take you directly to that part of the settings dialog.
0 -
Greg, Thanks again. Appending the default.pat worked fine.
0
