COM Programming
I have submitted the following as a support request but I thought that one of our resident brainiacs might be able to satiate my curiosity while I await an answer.
The following very simple code resides in a windows exe created in Delphi called qc.exe.
Var
App : IAutocadApplication;
Begin
App := IDispatch(GetActiveOleObject('BricscadApp.AcadApplication')) as IAcadApplication; //Get the active application object
App.ActiveDocument.SendCommand('5000,5000'#13#10);
End;
At this point the application does nothing more than return 5000,5000 to the command line (eventually the intention is that it returns a point transparently to an active command in BC eg line, polyline etc.
The exe is implemented through the following lisp:
(defun c:qc () (startapp "qc.exe") )
All files reside within the Bcad support path and run - (just not as i'd like). The output from a test run with the line command follows.
1. : line
2. ENTER to use last point/Follow/<Start of line>: 'qc
3. ENTER to use last point/Follow/<Start of line>: 2764
4. Angle/Length/Undo/<End point>: 5000,5000
5. Angle/Length/Follow/Undo/<End point>:
If you look at line 3 of the output you will see that bricscad is echoing some kind of handle or process ID to the screen which interferes with the program. Is there a way to turn this off or is it a bug?
Regards,
No: it's not a bug. If successful, startapp returns an integer greater than 2.
You can stop your lisp from returning this value by using:(defun c:qc () (startapp "qc.exe") nil)
But my guess is that your approach still won't work. I only know a few things about lisp though.
0 -
Or better still (?):
(defun c:qc () (startapp "qc.exe") (princ))
0 -
Thanks a bunch Roy; after adding the nil parameter everything works perfectly.
0 -
Dear Roy, Dear Daniel,
the last approach is formally correct, using (princ) to suppress any return;
using NIL will return NIL, which might disturb sometimes ... so (princ) is safer + more correct.0
