MY POPMENU CAN'T DISPLAY THE TEXT PROMPT
DEAR SIR :
MY POPMENU CAN DISPLAY THE TEXT PROMPT ON V10.2.8
BUT CAN'T DISPLAY THE TEXT PROMPT ON V10.4.8
THANKS
0
Could this knowledgebase item be related? https://www.bricsys.com/boa/knowledge/topic.jsp?id=289
Menus from the main CUI-file without a POP alias are by default no longer shown in the menubar. In order to show them an alias should be added for them.
0 -
Dera SIR :
MY POP-MENU IN THE partial CUI files. FROM THE TOOLBAR MENU USE LISP MENUCMD CALL : ^C^C(menucmd "p0=pop522");(menucmd "p0=*")
THE POP-MENU CAN WORK , BUT CAN'T SEE THE TEXT-STRING , JUST GRAY-BLOCK BAR
THANKS
0 -
That issue has been fixed and the fix will be included in next Bricscad version.
Many thanks for reporting !0
