Setting the "Save As Type" Default
in Other
My clients cannot open ACAD 2010 dwg files. I sometimes happens I forget to send them files that are 2007. Is there a way to set the "Save As Type" to a lower version and make this a default? How would one do this? Thanks.
0
Yes, you can change the SAVEFORMAT variable in the Settings dialog.
0 -
Greg, Thanks.
0
