Pack-n-Go?
in Other
Does BricsCad have a Pack-n-Go feature like ACAD whereby all the special fonts,hatch patterns, imported images, xrefs etc are grouped with the DWG for sending to others? or is there a plugin that does this? ...or is one left on one's own devices?
0
Look at command ETRANSMIT (also found on the File menu) or use the Drawing Explorer - Dependencies page. I can't remember just when it was added but if you are using a recent v10 release you should have it.
0 -
Greg, That was awesome! Even allowed me to delete the ttf fonts that my clients always pack up and send me. Thanks.
0
