Does V11 Classic Supports COM?
I've seen different answers to this question depending on where I was looking...
The developper reference says no: http://www.bricsys.com/bricscad/help/en_US/V11/DevRef/index.html
The online help says yes: http://www.bricsys.com/bricscad/help/en_US/V11/Bricscad/source/Installation_platforms_and_levels.htm
So what is the real answer? ![]()
Thanks !
Thank you. This is a good example of the condition that the Bricscad documentation is in.
I like Bricscad, but the documentation is crap and that is one of the saddest points about it.
0 -
There is a bullet marker missing in the developer reference: the COM API is included with a Classic version. We apologize.
To avoid misunderstanding: the VBA Integrated Development Environment is NOT included in the Classic version. So it is not possible to run .dvb code, but it _is_ possible to run e.g. a compiled Visual Basic program that uses the Bricscad COM API.
Hope this takes away any doubts that may have been left.
0 -
OK, we want to use the COM interface with some C#. Looks like it will work just fine with the Classic version then !
Thanks a lot
0
