TEXT problem with bricscad linux
Hi everybody.
I have a little problem with bricscad linux, and I would like to share it with you.
when I do a drawing in briscad linux everything looks good, but when I open the same file in windows, the text changes and the texts are moved too.
If I use briscad windows, Autocad open, without any change in the text, the file without problem. I think is a problem with the fonts of the Operating system, perhaps they are to much different.
I some body can help how to do something in linux and the text do not change when I open the file in windows will be great for me.
thanks a lot
jorge
Make sure you have some fonts available on both machines and use only these fonts.
0 -
thanks Mattias
but I checked that first, even... I installed the "ttf mscorefonts" package to have the fonts of microsoft and to prevent any problem of this case, but it didn't work correctly.
what more could I do?
thanks,
jorge
0
