fglrx display bug
Hi! there ![]()
I have laptop with hybrid graphics, in 11.8 Catalys driver was fixed the bug with hybrid graphics and finally I'm tested my own. I was suprised that bricscad did not display proparely in the drawing window with this graphics drivers (gallium 3D driver is OK)
video that shows the bug at youtube
somebody have any advise in fixing this? (other apps displayes fine including blender)
Hi Andrei
I also had troubles with the fglrx driver. But not only with Bricscad. The fglrx driver seems buggy, especially with the Evergreen series (HD5xxx).
I solved this by changing the parameter GLSWAPMODE ( Settings -> Settings ... -> Program Options -> Display -> GL Swap Mode ). I set it to "Call glCopyPixels to copy back to front, do not call glXSwapBuffers".I still have a little flickering with the selection rectangle, but nothing very serious.
I hope it will also solve your problem.0 -
Mandriva 2011, AMD 64bit, fglrx driver, ATI Radion HD 4200 Graphics Chip.
Using glswapmode = 3 here.
Any attempt to use a value of 4 causes a hang.
0
