Angular Unit Dimensioning
When I select two line for dimensioning (Decimal degrees) the decimal is rounded to the nearest whole number. I have the Angular unit precision set at 4 yet the number is still rounded. Any suggestions?
0
I believe this is set via DIMADEC. So even if your LUPREC (Linaer Units precisison) is set to 4, check the value of DIMADEC via the settings dialog.
0 -
That's it. Thanks.
0
