Batch drawing converter
Anyone know how to select a bunch of drawings and convert them all to acad 2004 or whatever format? Can't find a "batch converter" in V11. Thanks.
0
Tim, try this converter from the ODA: http://www.opendesign.com/files/guestdownloads/TeighaFileConverter/TeighaFileConverter_3.5.0_setup.exe. The files converted should be comparable as the libraries used are the same as Briscad.
Regards,
0
