Child Dimensions
I have this question regarding the child dimension style, Angular ($2), Diameter ($3), Radius ($4) and Leader ($7).
When I select the "_dimradius" command, is there a way to Bricscad to recognize that I have a dimstyle for that specific dimension. In AutoCAD it was automatic.
I'm using Bricscad V12.1.5, and I did not found any setting for that. I have to manually change the dimension in the Properties Bar---> Misc--> Dim Style -->... The flyout window give me the option of :Radius
Before I start working on a reactor for these situations, any opinion will be greatly appreciate.
Thanks
Thanks
0
Hi Simon,
as far as I'm aware Bricscad doesn't support child dimension styles, which is a pity as it is a useful feature. I Don't know if it's on their development horizon, suggest you raise a support request to get it added to the whishlist.Regards,
Jason Bourhill
0 -
I just sent the request... ID 324490
Hi Simon,
I send a support request (ID 24229) about this 13.05.2010
Status is
Closed - Feature request
Stanislav Pavlica0 -
OK, I'll see what they will answered me... I think I have no choice but to work on a reactor.
Thanks Stanislav0
