briscad text style
I receive a drawing from china which contain some Chinese character inside. When i open it using Bricscad it show ???:??. When i right click to properties wanted to change the font style i only can choose between standard and LSP but the result still the same. Any solution to view chinese font on briscad? I attach the print screen of the chinese character i open on Bricscad and Autocad.
0
Hi Eric, can you attach a drawing? I have most all the Asian fonts installed?
see if you can read this dwg
0 -
It seems there is a font missing or the font is getting substituted for one that's not unicode, all you need to do it choose tools->drawing explorer->text styles (or type style at the cmdline) and choose a Unicode font for the Standard type. Or, have the creator send you the font they used. Once I changed the font, the text shows
cheers!
0 -
thank Daniel for you help. I can see the font already. The creator did not send me the font they use0
