[Bricsys] New forum functionality
- New editor: When composing your message, it should be easier to place links and images. Numbered and unnumbered lists are supported as well.
- Insert code has been improved. The code preview will automatically resize to the amount of pasted code
- Attach files: It's now possible to attach multiple files (of maximum 5 MB) to your post. Viewable attachments (like images) will be displayed at the bottom of your post as thumbnails. When you click on them, the original size will be showed.
- Quote functionality: You can quote a previous post into your reply.
That's true. And here is some code[code].shareButton{float: left;margin-right: 10px;margin-top: 10px;margin-bottom: 10px;}[/code]0 -
[code]
bool CGsPreviewCtrl::GetPreviewIcon( AcDbBlockTableRecord::PreviewIcon &preview )
CDC *view = NULL;
HDC hdcMemDC = NULL;
HBITMAP hBmp = NULL;
bool status = true;
__try
// Retrieve the handle to a display device context for the client
view = GetDC();
if(!view)
status = false;
__leave;
HDC hdcViewDC = view->GetSafeHdc();
if(!hdcViewDC)
status = false;
__leave;
// Create a compatible DC which is used in a BitBlt from the View DC
hdcMemDC = CreateCompatibleDC(hdcViewDC);
if(!hdcMemDC)
status = false;
__leave;
int nWidth = 32;
int nHeight = 32;
// Create a compatible bitmap from the View DC
hBmp = CreateCompatibleBitmap(hdcViewDC, nWidth, nHeight);
if(!hBmp)
status = false;
__leave;
// Select the compatible bitmap into the compatible memory DC
HBITMAP hOld = (HBITMAP)SelectObject(hdcMemDC, hBmp);
if(!hOld)
status = false;
__leave;
// Bit block transfer into our compatible memory DC.
if(!BitBlt(hdcMemDC, 0, 0, nWidth, nHeight, hdcViewDC, 0, 0, SRCCOPY))
status = false;
__leave;
// Get the BITMAP from the HBITMAP
BITMAP bmp;
if(!GetObject(hBmp, sizeof(BITMAP), (LPVOID)&bmp))
status = false;
__leave;
// Calculate the sizes for our memory a 32 x 32 x 8 looks like
// |...BINFOHDR-40...|....RGBQUAD-1024....|....BMPDATA-1024....|
WORD cBitCount = 8;
DWORD dwBmpSize = ((bmp.bmWidth * cBitCount + 31) / 32) * sizeof(RGBQUAD) * bmp.bmHeight;
DWORD dwSizeofDIB = dwBmpSize + sizeof(BITMAPINFOHEADER);
DWORD dwSizeofALL = dwSizeofDIB + dwBmpSize;
// alloc all memory
preview.setLogicalLength(dwSizeofALL);
BITMAPINFO bmpInfo;
ZeroMemory(&bmpInfo,sizeof(bmpInfo));
// Info for the header
bmpInfo.bmiHeader.biSize = sizeof(BITMAPINFOHEADER);
bmpInfo.bmiHeader.biWidth = bmp.bmWidth;
bmpInfo.bmiHeader.biHeight = bmp.bmHeight;
bmpInfo.bmiHeader.biPlanes = 1;
bmpInfo.bmiHeader.biBitCount = cBitCount;
bmpInfo.bmiHeader.biCompression = BI_RGB;
// stick the bmpInfo in our array;
CopyMemory(preview.asArrayPtr(),&bmpInfo,sizeof(BITMAPINFOHEADER));
// Gets the "bits" from the bitmap and copy them into our preview array
if(!GetDIBits(hdcViewDC, hBmp,0,(UINT)bmp.bmHeight,
preview.asArrayPtr()+ dwSizeofDIB, //copy BMPDATA
(LPBITMAPINFO)preview.asArrayPtr(),DIB_RGB_COLORS)) // init BITMAPINFO
status = false;
__leave;
__finally
DeleteObject(hBmp);
ReleaseDC(view);
DeleteDC(hdcMemDC);
return status;
[/code]
0 -
Nice work!0
Nice work!Thank you0
[code]#pragma once#include "BrxCoucheManagement.h"//-----------------------------------------------------------------------------//----- Here you can store the document / database related data.class CDocData {//----- TODO: here you can add your variablespublic:CDocData () ;CDocData (const CDocData &data) ;~CDocData () ;} ;[/code]0
Test...
With the old editor copy-pasting a piece of html text could lead to (hidden) html formatting being copied a well.
Copy-pasting some html text: Sander Scheiris0 -
Test...
So that problem still persist.0 -
... The Attach files functionality is of course very nice!0
0
Test...
Copy-pasting some html text: Sander ScheirisRoy,For some posts it can be a problem, for other posts it's helpful.If you want to avoid this, you will have to "Paste Special" to paste the text with no formatting.Best regards,Sander0 -
#pragma once#include "BrxCoucheManagement.h"//-----------------------------------------------------------------------------//----- Here you can store the document / database related data.class CDocData {//----- TODO: here you can add your variablespublic:CDocData () ;CDocData (const CDocData &data) ;~CDocData () ;} ;LPDISPATCH Item(VARIANT Index){LPDISPATCH result;static BYTE parms[] = VTS_VARIANT ;InvokeHelper(0x0, DISPATCH_METHOD, VT_DISPATCH, (void*)&result, parms, &Index);return result;}0
I would like to be able to edit my old postings.
Anything like that in planning?0 -
Anything like that in planning?There are no such plans for now.0 -
Is it possible to DELETE an attachment while working on a message?0
Request:
I would like to see a [Log in] button/feature on each forum page. Now I have to log in via the Meeting Point and then switch back or click on some attachment.0 -
+1 for log in button. I am not a fan of the meeting point. I am sure it fits into the workflow and mindset of a lot of people but trying to fit answers into a set number of characters really irks me
Also having to scroll up and down to find the initial message in a thread isn't very fun either. Just my 2 cents. 0 -
Hi,We will implement a logon button somewhere Q1 2012.Sander0
Great, thank you.Hi,We will implement a logon button somewhere Q1 2012.Sander0 -
TEST... TEST
The forum software doesn't 'like' pointy brackets:
Let's see if this works: < >0 -
... To get correct pointy brackets:
For < (less than) use: <
For > (greater than) use: >0 -
Of course pointy brackets are also used in Lisp code.
Test Example:
[code](setq ss
(ssget
(list '(-4 . " '(0 . "LINE")
'(0 . "LWPOLYLINE")
'(0 . "POLYLINE")
'(0 . "ARC")
'(-4 . "OR>")
[/code]0 -
In my previous post the display of the first -4 gc is incorrect. It seems wise to always (also) attach your Lisp code.
Another test example:
[code](setq ss (ssget (list '(-4 . ""))))[/code]0 -
Yes, that could cause some "problems"... A disappearing act most likely.
Some HTML of the posts get parsed/filtered out etc
Maybe we can try to find a way to recognize it better in a next iteration.0
