Dynamic Blocks - How to change Visibility programmatically
Hello,
I have a request from a GeoTools user who is using both BC and AC. This question applies to both software.
How do I change the visibility custom property of a dynamic block programmatically using Lisp.
I have a dynamic block with two different hatch patterns appearing when the Visibility property is changed manually. Question is - how to do it programmatically via Lisp?
Any tips welcome.
    Regards
    Rakesh Rao
www.4d-technologies.com
            Hi Rakesh,Check out lee-mcdonnell's site on the subject.Regards,Daniel0
Daniel,
I am getting back to you really late but I want to thank you for showing this site. Indeed, the Lee Mac site has wonderful tools for management of dynamic blocks. I did use a couple of routines from there and it worked very well.
Regards
Rakesh Rao
http://rakeshrao.typepad.com0
