SPLINE bug
when you draw a spline with the standard linestyle hot_water_supply (label HW) in some cases the label is displayed mirrored...
You can see the label switching from HW to WH in preview mode when changing the cursor position to the next point.
See attachment example.
0
This forum is meant for user-to-user communication. To report bugs, please use the Support Request pages, which are specifically set up to report bugs, and allow efficient handling. Thanks for your understanding.0
i did, more then 2 weeks ago, not any responce yet...0
"Not any response yet?"
Why not say things as they are?
On 2012/02/08 you _did_ receive a response: our analyst had the impression that acad displayed the linestyle in the same way as Bricscad.
Upon which you insisted to check more carefully.
And to say things as they are: you do have a point, there is indeed an undesired mirror. We have reported this issue to ODA as the error occurs in their Teigha libraries.
We will keep you informed when a fix becomes available.0
