V12.1.16
in Linux
all my rendering issues with 3D Context seem to be gone. Thanks
in one of the betas it was suggested to fix a menu timing issue to set "QAFLAGS (0 to 32767) <0>:' enter '16384'".
i'm still not getting a text/pulldown menu and i still have all the warnings every time i start up.
what do i reset to go back to the default and make the warnings go away?
I'd like the text menu, but will live with out it for now.
Tia
Tia
0
set "QAFLAGS (0 to 32767) <16384>:' enter '0'worked for me. This will avoid display of the menu creation diagnostic pop ups.I'm pleased to report that version 12.1.16 running under Ubuntu 11.10 on an Intel Atom D510 processorruns just fine for 2D drawings. I've not tried it for 3D work as I expect it might be too slow a cpu.0 -
Thanks
and fwiw, you can do 3D in 2D mode if needed.0
