Edit MText object in Bricscad using vb.net
Hi,
Please help me, How can I edit the MText object which is placed in ModelSpace of bricscad using vb.net. I need to edit the text with vb.net so how I find the index of particular text or start point of the text.
Thanks in advance
SSD
Thanks in advance
SSD
0
Here is a sample in C# , sorry too much vb will make me go blind ; ^ )
0 -
just copy and pase the code here for VB http://www.developerfusion.com/tools/convert/csharp-to-vb/
Also you can use reflector : )
Cheers : )
0
