Conversion V5 CommonProjects.VBI into a V12 DVB
Does anyone know how to convert my old CommonProjects.vbi from version V5 into the V12 DVB version when I do not have the BricsCAD V5 PRO version available anymore?
I know I have to tweak the old style programming rules in V12 to the new DVB rules but up till now I can't import or translate the VBI into a DVB. It's not ASCII alas so can't use Notepad either.
HELP :-( Thanks for looking into the situation
a.
0
Hi Arjen,
Bricsys have an online tool for converting older VBA http://www.bricsys.com/common/vbaconversion/. However this looks to require that you have access to the original file in text format. I would suggest that you raise a support request. They can probably make an earlier version of Bricscad available to you.
Regards,Jason Bourhill
0
